77 Chevy not starting
Old Jun 3, 2012 | 1:33 PM
avoos's Avatar
Default 77 Chevy not starting
My truck will not start. I had some issues with the starter so I replaced that and it ran just fine for about a week, now it will not start. I have checked the battery and alternator and both are just fine. The only puzzling thing that I can't figure out is with a test light I get no charge through my positive battery terminal and I get a charge out of my negative terminal, I think this is backwards am I correct? Any ideas would help. Thanks
Old Jun 3, 2012 | 5:41 PM
With a test light light you get a light with one probe from the light to the positive of the battery and the other to ground. You get no light from negative battery terminal and the other to ground. It is impossible to get it the other way around!
Old Jun 3, 2012 | 9:55 PM
avoos's Avatar
That is exactly what I thought, but I am getting the opposite. If I ground the light and then touch the negative terminal, the light turns on. If I use the same ground and touch the positive terminal, nothing.
Old Jun 4, 2012 | 9:10 AM
Disconnect all the cables from the battery and try it again. If it continues to do the same thing the battery must be bad or the terminals are marked wrong on the battery.
trunks9_us
Dec 8, 2012 1:21 PM
jamster00
Nov 7, 2011 10:29 AM
krustyjonez
May 17, 2011 8:02 PM
tony505
Jun 15, 2009 5:00 PM
