91 Chevrolet truck heat control Help??
Old Mar 30, 2011 | 7:22 PM
mechanic-in-training24's Avatar
Default 91 Chevrolet truck heat control Help??
I have a 91 Chevrolet 2500 Silverado Truck. My problem is....my Air blows only on the Floor mode, no matter what "Try" to turn it to? It blows air, heats fine.....Blows out Very warm or cold air (High or Low) Its just stuck on The floor....it won't swithch to vent or Defrost. Can someone please Help with problem?? Thanks
Old Mar 31, 2011 | 8:21 AM
tinbender59's Avatar
look at the heater box beside your left foot (as you set in the drivers seat) there are 2 boxes or modules one low and one hi. watch these and move the settings on HVAC controls. watch for movement and noise from them. there is also linkages on both, they need to be checked. I have a gallon can of modules, I'll let you have one or two for shipping. if nothing happens it is more than likely you're controller, and I do not have one of those.
Old Mar 31, 2011 | 11:13 AM
Rob G's Avatar
My controller cable broke and was stuck on the vents. Took it to the mechanic, they switched the flaps to defrost mode for me as this was the most important need. (frost every morning)
I did't have the extra money for the repairs as my extisting repair bill wa $1200 already
going five years this way and I am ok with it.
Old Apr 1, 2011 | 6:46 AM
Default Thanks!!
Yea......I ash around at the dealership the other day and was told to look there!! The actuators work....looks like the bracket that holds the actuator broke and in turn it broke the end on the flap.....as it was cocked up and put it in a bind!!
Does anyone know how hard it is to change that flap? Looks like the dash will have to come off?? Or maybe a way to fix this??
Old Apr 1, 2011 | 6:50 AM
I was able to swithch from floor to defrost mode bye flipping the flap bye hand......once I took the actuactor off!!
Old Apr 1, 2011 | 11:46 AM
Rob G's Avatar
For my truck...the cable cost $125.00 and the labor was about $100 more. Yes they will have to take off the dash..time consuming!
Muskovin
10
Feb 27, 2020 6:45 AM
jmarkv
Jan 24, 2012 8:21 PM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
