91 K1500 driving me crazy!!! Hesitate/stumble/cut-out
Old Aug 20, 2012 | 1:32 AM
sherman943's Avatar
Default 91 K1500 driving me crazy!!! Hesitate/stumble/cut-out
Hello, Looking for a little help. I have a 91 silverado 5.7 350
I can't find the source of the following problem. It has a hard cold start problem (long crank time) then when warm it will idle rough or stumble/ cut out but doesn't die. It also does this on real light acceleration, the tach will bounce up and down and you can hear it. But runs fine on the highway and hard acceleration. Not sure if the starting and stumbling problems are related. A lot of work has been done to this pickup since November of 2011 so I will list them to hopefully eliminate some possibilities.
-Engine overhaul in Nov. 2011
-New fuel pump and filter
-New water pump
-Plugs/Wires/cap/rotor
-spark control module
-ignition control module
-ignition coil
-map sensor
-throttle position sensor
-IAC
-Egr valve
-Egr control solendoid
-all vacuum lines
-removed and cleaned throttle body/new gaskets
-both injectors
-Exhaust including catalytic converter and muffler
-Alternator and Battery
Tried the old trick of spraying carb or brake cleaner to find vacuum leaks with no results. No service engine light and no stored codes.
What the heck is going on with this thing? Thanks in advance for any help, Shayne
Old Aug 20, 2012 | 5:43 AM
maxxman04's Avatar
sounds like plug wires are out of order. or timing.
Old Aug 20, 2012 | 10:52 PM
sherman943's Avatar
was a good thought, so i checked it out, unfortunately the plug wires were right
Old Aug 24, 2012 | 1:06 AM
sherman943's Avatar
could this be an oxygen sensor? Bout the only thing that hasn't been changed
Old Aug 24, 2012 | 1:08 AM
sherman943's Avatar
or would that set off the check engine light?
Old Nov 10, 2012 | 12:34 AM
boernerbruce's Avatar
I have the same exact problem. It also hits second gear hard
Old Nov 10, 2012 | 1:50 AM
sherman943's Avatar
Turns out the problem (for my pickup anyway) was solved by unhooking the vacuum line from the egr valve and plugging it with a screw. Not sure why considering that it has a bran new egr valve, egr valve gasket, all vacuum lines replaced, egr control solenoid. Mechanic told me what is happening is the egr valve for what ever reason isn't completely closing when it should then it sits there and flutters causing all the problems.
Old Nov 10, 2012 | 6:31 AM
Will definately try this as soon as it daylight. Thanks
senter9
Mar 17, 2015 5:32 PM
hockey4ever
Feb 16, 2015 9:01 AM
luckydriver
Apr 9, 2014 9:26 AM
seandw
May 16, 2011 1:17 AM
David2.5
Sep 7, 2008 9:24 PM
