92 SILVERADO TURNING OVER BUT NO POWER
Old Nov 30, 2007 | 4:43 PM
RHYS's Avatar
Default 92 SILVERADO TURNING OVER BUT NO POWER
I have got a 92 silverado extended cab 4x4 which is used as plow truck. Last night truck was working fine, but then suddenly cut out, no power, no lights, no power windows. The truck is turning over but will not start, even when i am trying to turn the engine over i still have no power lights etc. The battery is fine becasue i am able to raise the plow etc but now the truck is not working and i have the windows down on the truck and not able to rasie them with alot of snow coming!! (I have checked the internal fuses and they look ok)
Old Nov 30, 2007 | 5:49 PM
Outcastz89's Avatar
Default RE: 92 SILVERADO TURNING OVER BUT NO POWER
Have you checked fusible links?Or the battery ground cable?Clean your battery up.Can you hear the fuel pump turn on?Is there gas getting to the engine?
Old Nov 30, 2007 | 5:53 PM
Yellow Walls's Avatar
hope you get it up and running soon!
Old Nov 30, 2007 | 7:41 PM
RHYS's Avatar
just got back from plowing in my odld truck and still cant get other truck to work. Fuel pump turns on and there is gas getting to the engine. And the battery cable is good and grounded. like i said even when i turn the ignition on without trying to start engine i have no pwer lights etc. Its strange becasue i was plowing and it simply stopped all lights off everything, i didnt bump the truck which would mean i might have loosened something so im open to answer. the weather is so bad at the moment so not able to have a good look, but i have checked most things over.
Old Nov 30, 2007 | 9:44 PM
jlm6740's Avatar
Sounds like a fusable link to me too.
Old Dec 1, 2007 | 10:50 AM
RHYS's Avatar
Sorry i know a bit about cars brakes oil etc but electrics not much good what is meant by a fusable link? is it difficult to fix and costly? thanks for the advice so far..
Old Dec 1, 2007 | 5:55 PM
RHYS's Avatar
Thanks Outcastz89 just cheked the ground cable and it had snapped loose! It was the simplest thing to fixed thanks for your help, now i have two plow trucks to get rd of all this snow!!!
Old Dec 1, 2007 | 6:56 PM
Outcastz89's Avatar
Your very welcome.Hope plowing goes well.Been doing a quite a bit of snowblowing here.Now I just gotta figure out what's wrong with the 4 wheel drive on my 92 k1500.Hope nothings really broke.
xcesmess
Apr 5, 2021 2:07 AM
JOUT22
Mar 8, 2013 3:13 PM
thisnthat
Nov 20, 2012 11:36 AM
triple_b
Nov 27, 2006 10:55 PM
