94 K1500 350 tbi
Old May 8, 2010 | 12:18 PM
hollerin big's Avatar
Default 94 K1500 350 tbi
I have a 94 model 350 with TBI motor. I had to put two new heads on it last weekend, I set the timing on TDC and adjusted the valves like the Haynes book said to, but when I crank it up it lopes real bad when the timing is on 0 I have to advance it 32 degrees to get it to idle right and then when I put it in drive it will start missing so bad it shuts off I have been back through the valves again and have moved the distributor numerous times. I'm at a loss with what to do does anybody on here have any suggestions.
Old May 9, 2010 | 10:12 AM
Speedy650's Avatar
theres a wire you have to unhook in order to correctly set the timing, did you do this when you set the timing? if not that could be a reason why its not working.
Old May 9, 2010 | 6:59 PM
72c10gunn's Avatar
i think speedy hit the nail on the head...i think its the map sensor wire...check the manual to be sure
Old May 10, 2010 | 11:20 AM
Yes I have unhooked that wire I've known about it
Old May 10, 2010 | 7:38 PM
Speedy650's Avatar
double check all connections and double check that they are where they need to be. check any wiring having to do with ignition to make sure its all ok. also, check your throttle body and fuel lines coming into it just to make sure. its hard to pinpoint this. maybe a certified mechanic can better diagnose this.
chrisz71
Apr 13, 2013 9:03 PM
Baldzilla51
Apr 8, 2013 7:36 PM
tech180
Jan 31, 2013 4:25 PM
computerdude14
Jan 8, 2013 3:33 PM
2000sdime
14
Oct 20, 2010 2:14 PM
