95 5.7 "Cat" removal
Old Jul 26, 2012 | 8:42 PM
ncsouthpaw's Avatar
Default 95 5.7 "Cat" removal
I have a 95 Silverado with a 5.7 engine, what effect will it have on the running if the Cat is removed. Anything else need to be done to keep the truck running smoth.
Thanks for any advise Ronnie
Old Jul 27, 2012 | 6:27 AM
shamrock246's Avatar
Not sure you would gain anything unless it was clogged
Old Jul 27, 2012 | 7:16 AM
ncsouthpaw's Avatar
It's not clogged but it rattles like the material inside is loose.
Old Jul 28, 2012 | 12:41 AM
66nova's Avatar
It will be louder and that is about it. I ran my 95 without a cat for quite a while then stuck one back on it once I moved to Texas and had to get it inspected. I actually think I got better mileage with it on. I did install a Magnaflow cat from Jegs because it was a ton cheaper than a stock replacement.
Old Jul 28, 2012 | 8:15 AM
I would replace it before all that crap ends up clogging the muffler it happened to my 83 chevy wagon,how is the 95 setup single in and out?i would check out JEGS also maybe one of the universal types would work
Old Jul 28, 2012 | 8:48 PM
ncsouthpaw's Avatar
Yes it is a single in and out.
Old Aug 2, 2012 | 12:55 AM
Doug Roberts's Avatar
I have a 99 with a 5.3 and was told pb will kill values i want my cat gone
Old Aug 3, 2012 | 3:20 AM
Mudd Mutt's Avatar
Taking the cat off will burn up your valves to where your engine will have no compression and no power. You have to have some back pressure. If you have a muffler your fine but without anything it all you'll be buying a new engine in a year
damone
May 8, 2021 12:36 PM
Platinum
Jan 16, 2019 9:53 PM
ericnottelin
Jul 2, 2012 10:03 PM
chevyman323
Jul 16, 2010 11:56 AM
mike688
Uplander
Jan 25, 2010 12:16 PM
