95 c1500 engine ticking? any help?
i have a 95 chevy with 350 and auto. at idle engine sounds like it has a manifold leak but when you gas it is a really loud ticking, doesnt do it in park or neutral when reved up, only with a load on it. any help would be greatly helpful
RE: 95 c1500 engine ticking? any help?
you might have a collapsed lifter or a bent pushrod. if your engine has substantial miles on it you might just need your valves adjusted. a loose rocker arm will tick pretty loud. i would probably pull off the valve covers and pull the push rods make sure they arent bent and then re-adjust the rockers. something for the shadetree mechanic but if you only know how to put gas in and change the oil id take it to the pros.
Melody Smith Arquillo
December 3rd, 2012 12:48 PM
CarK1ng
October 17th, 2011 7:58 PM
