Old Jul 22, 2015, 11:44 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
95 Chevy Silverado will not shift into 4wd
Old Dec 1, 2009 | 6:22 PM
Lostkat7's Avatar
Default 95 Chevy Silverado will not shift into 4wd
my 95 Chevy 4 wd will not engage when the shifter on the floor is shifted to 4hi or 4 lo, the lights do not indicate 4 wd and the front end does not engage, any ideas.......
Old Dec 1, 2009 | 7:15 PM
silverado08's Avatar
check the fuse. then check the actuator.
Old Dec 1, 2009 | 8:48 PM
nauticstar87's Avatar
when you put it in 4-lo can u feel the gear change when you move forward.
Old Dec 2, 2009 | 9:57 AM
Lostkat7's Avatar
Angry
silverado08, where do I locate the actuator, I have heard this possibility before, but have no idea where to locate it...
nauticstar87, you don't feel anything when you move the shift lever into any of the 4 wd ranges....
Old Dec 2, 2009 | 11:58 AM
therewolf's Avatar
Cool
Hi Lostkat7,
Welcome to the Chevy Forums.
I'm just going to assume nothing here, are you aware that to shift into 4LO you have to put the transmission in Neutral first?
Old Dec 2, 2009 | 2:31 PM
gotstylez's Avatar
well he says he feels nothing.. when u put my truck into 4wd.. it takes a little force.. its not easy but its not hard. and everynow and then i dont do it fast enuff and i grind a gear in the t-case.. so if you dont feel anything when u shift it into 4wd.... bad t-case maybe? put it in 4wd and go under neath the truck.. grab the front driveshaft and rotate it..if it turns thats bad.
Old Dec 2, 2009 | 8:05 PM
the actuator is located above the front skid plate by the differential. if you feel nothing at all when u shift into 4low then it would be a transfercase prob like Gotstylez said.
You might want to make sure the linkage from the pole to the transfercase is there.
Fish Killer
Apr 16, 2025 10:01 PM
Russ Hayes
11
Sep 15, 2017 3:12 PM
toolvan
May 15, 2015 9:34 PM
RIGGS123
Jul 9, 2014 5:29 PM
DianaT
Nov 29, 2007 12:12 AM
