96 silverado cranks up then shuts down
my 96 5.7 vortec starts up fine with no issues goes into high idle then shuts down. it ran fine then would not start one morning at all. adjusted the time and now it starts fine high idles and shuts down. if you give it any gas it shuts down
The oil pressure switch could be bad it takes over suppling the fuel pump with power once the oil pressure comes up to a certain point,there is a single wire with a black connector by the fuse/relay box if you put 12v to it it will run the fuel pump all the time
Jonrogers0760
August 8th, 2011 11:24 AM
Wibble
June 23rd, 2011 2:54 PM
grassman
March 3rd, 2011 9:16 PM
bighoss
January 21st, 2011 3:58 PM
