96 silverado cranks up then shuts down
Old Oct 11, 2012 | 10:09 AM
emtjloghry's Avatar
Default 96 silverado cranks up then shuts down
my 96 5.7 vortec starts up fine with no issues goes into high idle then shuts down. it ran fine then would not start one morning at all. adjusted the time and now it starts fine high idles and shuts down. if you give it any gas it shuts down
Old Oct 11, 2012 | 11:15 AM
Is the check engine light on? Check your fuel pressure. Really need more information, there are too many things that could cause what you describe.
Old Oct 11, 2012 | 5:26 PM
emtjloghry's Avatar
no lights fuel pressure is good i wish i had more to tell but thats it
Old Oct 11, 2012 | 6:50 PM
shamrock246's Avatar
The oil pressure switch could be bad it takes over suppling the fuel pump with power once the oil pressure comes up to a certain point,there is a single wire with a black connector by the fuse/relay box if you put 12v to it it will run the fuel pump all the time
Old Oct 12, 2012 | 7:48 AM
emtjloghry's Avatar
thank you ill give it a try when i get off
hardhead
Apr 6, 2015 10:21 PM
Jonrogers0760
Aug 8, 2011 11:24 AM
Wibble
Jun 23, 2011 2:54 PM
grassman
Mar 3, 2011 9:16 PM
bighoss
Jan 21, 2011 3:58 PM
