96 Silverado Need help with 4.3L Engine Mount Change
Old Mar 6, 2011 | 2:58 PM
OE812's Avatar
Default 96 Silverado Need help with 4.3L Engine Mount Change
I own an 01 Silverado with the 5.3 L and am looking at getting a 96 Silverado (C1500) with the 4.3L. The engine mounts need changing according to the owner. I do not have the Haynes manual and need assistance on the steps needed to change the mounts.
The owner stated that he thought I could lift the engine, detach the coil springs, and remove the mounts.
Anybody have the steps on changing the mounts?
Thanks,
Jeff
Old Mar 6, 2011 | 5:12 PM
RacerX's Avatar
disconnect the motor mount bolts, jack the block up with a wooden block on the floor jack right under the oil pan or crank pulley and then reach in and remove mount bolts left and right, 2 on each mount.
Space will be tight unless you also remove the trans. crossmember mount.
Old Mar 7, 2011 | 1:44 PM
OE812's Avatar
RacerX:
Thanks for the information on the mounts. Another problem is cylinder 1 is fouling. Compression reading is 150 max. using about 1/2 quart per 400 miles. Any quick and dirty fixes on this without replacing engine?
Old Mar 7, 2011 | 6:02 PM
OE812's Avatar
Just got back from doing a compression check on no. 1 cylinder. This is the one that he owner states that once a year he has to change a fouled plug. I pulled the plug and it was crushed white on the electrode. Anyway the compression came back at 150. It started leaking down slowly from 150.
Is 150 ok for a truck with 280000 miles and does it point more to valve seals?
Starboy
Sep 21, 2022 3:08 PM
davec66
K5 Blazer
Jan 7, 2011 10:47 PM
DeHartShadow
Mar 28, 2010 10:10 PM
furcioelbraveado
Dec 29, 2009 10:21 AM
Znelwonders
Feb 23, 2008 8:16 AM
