96 suburban won't start
Old Jul 18, 2012 | 9:28 AM
wizardsinsight's Avatar
Question 96 suburban won't start
Fuel Pump pressure within spec. Will not start with either. Tries to start but won't. Replaced ignition control module. started once but not again. Remove fuel lines from manifold and soaked with fuel injection cleaner. Don't know how to tell if the injectors are actually pumping fuel. When It did run idle was rough and when you pressed the accelerator the engine died. Was very difficult to start. Battery was shot so I just put a battery in. Wanted to read codes but doubt there are any stored since battery has been dead for a while.
Any help appreciated.
Old Jul 18, 2012 | 9:59 AM
PerusTC's Avatar
Have you checked the Distributor cap and rotor?My truck had the same problem until I R&R'd those components.Now it runs great.'94 C2500 454.
Old Jul 18, 2012 | 11:29 AM
It had spark so I did not physically check them for cracks or damage. I will do that. thanks.
Old Aug 25, 2012 | 8:32 AM
Replaced cap and rotor. Still won't start. Did leak down test on fuel system and it passed. Suspect the fuel injectors are not working.
Removed upper plenum and think fuel injectors are clogged. trying to clean now.
Old Aug 25, 2012 | 9:53 AM
maxxman04's Avatar
have you checked for spark at the plugs at all?
Old Aug 27, 2012 | 1:31 AM
jesse06's Avatar
wow man fuel injectors all clogged up? someone spike your gas tank??
Old Aug 27, 2012 | 6:38 AM
shamrock246's Avatar
Will it run if you poor some gas down the throttle body?
Old Aug 27, 2012 | 1:59 PM
yes, it will run with either as long as you keep putting it thru the throttle body. As soon as you stop it dies.
Old Aug 27, 2012 | 2:04 PM
kevinkpk's Avatar
You need a test light, while cranking to see if your getting voltage to the injectors.
Old Aug 27, 2012 | 4:27 PM
What kevin said and did you check the fuses ECM-1,ENG-1 both 20 amp
