97 1500 missing
Old Mar 1, 2012 | 12:38 PM
Cglen91's Avatar
Default 97 1500 missing
Hey how's everyone doing? I have a 97 k1500 with the 5.7 vortec. In the mornings when I start it up it misses really bad and gives the p1345 code cam sensor not in correlation with crank sensor. I drive it hard for about 5 minutes until it warms up, then it runs fine. Any help is appreciated.
Old Mar 1, 2012 | 5:19 PM
nkh34's Avatar
maybe try readjusting the timing or check the timing chain seems weird that it is fine after it warms up
Old Mar 22, 2012 | 5:01 PM
Cglen91's Avatar
Update. It does it worse when it rains. I think im getting moisture in it somewhere. Where could moisture be getting in at?
Old Mar 22, 2012 | 5:23 PM
Cglen91's Avatar
I changed to rotor button and cap a few months ago. I was reading a thread about Astro vans say that the aftermarket caps aren't good and cause moisture to get it. Is this true on the the 350's also?
Old Mar 22, 2012 | 6:58 PM
shamrock246's Avatar
I had a cheap cap and rotor do that same thing only when it rained(hard starting) if the rotor dosen't have the plastic shield covering the metal section(mine was blue in color) going out to the tip it will arc up to the cap and to wrong cylinder i could see the small arc spot on mine get a good AC/DELCO set
Old Mar 23, 2012 | 1:04 AM
Cglen91's Avatar
Alright thanks im going to try that.
stevetro1
Aug 14, 2020 3:36 AM
c.parry95
Mar 24, 2014 5:03 PM
jordan.morgan
Feb 24, 2013 10:51 PM
chevy1500cht
23
Dec 30, 2012 8:46 PM
bjf1280
Sep 30, 2012 12:00 AM
