98 k1500 4x4 Brake problems
Old Dec 24, 2014 | 5:51 PM
Huggy Bear's Avatar
Default 98 k1500 4x4 Brake problems
My rear brakes seem like they are always on. Pedal for the most part seems fine but sometimes when depressed it is at the top of range? Also when stopped at a light when taking off I get a noise that seems like the brakes are stuck? Not sure what is going on. Any help or info would be appreciated. Thanks
Old Dec 24, 2014 | 9:27 PM
mel902's Avatar
Check your emergency brakes.I have a 98 and had a yearly inspection done on it.The mechanic checked the rear brakes and said everything was fine.Now when i left the shop,i felt the rear brakes were slightly on.I though the shop might have adjusted them up and the would seat themself in time.But after a few days one tire would lock up randomly ,so i took the tire off and the emergency brake cable end was being pinched by the shoe,which in turn would engage the emergency brake on that tire.So i just took a flat blade screwdriver and pried the cable end out bit and it fixed the problem.
Gmangh15
Nov 7, 2012 12:20 PM
keninandrews
Feb 19, 2012 10:36 PM
keninandrews
Feb 19, 2012 7:17 PM
sf112624
Feb 28, 2011 7:55 PM
XC_Racer_129
Jan 13, 2011 11:31 AM
