98 sierra tranny problems HELP!!!
it wont go in reverse. it will go into 1st, and will shift to 2nd, but at a high rpm, and there is no CEL. I dont get it. please help.
Everytime I've burnt up a trans, reverse was first to go, then it started shifting odd. You may just have a bad sensor, I don't know much about those electronic trans though...
so, you dont have reverse at all, any noises when trying to engage reverse? what about when engaging first? what rpm does it reach when you engage second? there 3rd? 4th? od? is your speedo reading correctly? depending on the answers it could be a simple solution, or a broken sunshell. so give some very detailed answers and i can help you out more. <table class="product_table" id="product_table" border="0" width="96%"><tbody><tr><td>1st and 3rd only, will not work in 2nd ,4th or Reverse</td> <td> </td> <td>sunshell is fractured or splines are sheared off. Try not to run or drive the car or further damage could result.</td></tr></tbody></table>
A. T
November 29th, 2011 5:03 PM
DeHartShadow
March 28th, 2010 10:10 PM
89silverado283
February 16th, 2010 8:50 AM
revamped
August 24th, 2008 10:48 PM
revamped
January 23rd, 2008 4:03 PM
