98 Silverado fuel injectors SCFI vs MPI
Old Apr 4, 2012 | 10:32 PM
SweetEmotion's Avatar
Default 98 Silverado fuel injectors SCFI vs MPI
I am assembling my freshly remaned 350 vortec and want to replace the old injectors. Whats the benifits of this new MPI injection ive heard about? Is it worth the money to upgrade? I found this set up on Amazon -Delphi FJ10566 Fuel Injector $271. Is this a good one to go with?
Old Apr 5, 2012 | 6:52 AM
shamrock246's Avatar
1-the poppets can stick closed causing a missfire on that cyl(mine jammed closed causing a dead cyl)
2-they stick open causing missfires and poor running
3-the old regulator can leak dumping fuel into#5 and#7 more running problems
4-they can intermitantly stick causing misfire to come and go
5-mine ran smoother
6-it will give you problem in the middle of winter (thats my luck)
hang the old one on the wall and wonder what the F@#$ was GM thinking
Old Apr 7, 2012 | 10:06 PM
96 Junk That Moves's Avatar
I have a 96 with sticking poppet valves. MMO in the gas helps but I will upgrade. If you are assembeling a new engine do yourself a favor and upgrade from the start.
Just my HO
Old Apr 8, 2012 | 7:08 AM
jgray152's Avatar
i thought MFI,MPI,SCFI,MPFI were just different terms used for the same thing? the upgrade injector design doesn't change the name or term...
Old Apr 12, 2012 | 8:53 PM
Ryan Colorado's Avatar
So many names to confuse us. Hope they used the money that they earned "well" back then. Idiot engineers.
chnaus
Dec 10, 2010 4:06 PM
maxxman04
Feb 13, 2010 1:03 AM
Colt Hero
Apr 30, 2008 4:03 PM
thommcbr1
Jan 12, 2008 10:03 PM
art
Apr 9, 2007 4:48 PM
