99 4.8 CPS problems...HELP!!!
Old Mar 11, 2011 | 11:46 PM
Tommy99's Avatar
Default 99 4.8 CPS problems...HELP!!!
I recently had the CPS replaced in my truck. The mechanic drove itfor about 15 miles afterwards with no problems. I drove it home about 2 miles futherno problems. Next morning the truck will hardly run, same problem as before. Drove back to the shop, and did another step which called for the motor to be run up to 4500rpm for the computer to reset somehow. Seemed better but still has the miss but not as bad. Is there any futherr steps to take in solving this problem???
Thanks.
Tommy99
Old Mar 12, 2011 | 12:02 AM
EinST's Avatar
I don't know about the "4500rpm" thing but there's a CKP system variation learn procedure that requires the scan tool. Unless by "CPS" you don't mean the crankshaft position sensor?
Old Mar 12, 2011 | 1:20 PM
Tommy99's Avatar
Yes that is the part I'm talking about. What is this CKP deal about? How does it work?
Old Mar 12, 2011 | 1:35 PM
EinST's Avatar
It's something they do in the service department after changing a CKP sensor, i.e., hook up a Tech 2, select CKP system variation learn procedure, and then follow the direction it gives. The way I understand, it calibrates the VCM to the new CKP sensor. There must be slight signal variation among sensors.
Old Mar 13, 2011 | 7:16 PM
loosebearing's Avatar
How bad of a miss? I do not think cps was your problem from the start.
What code was you getting? I know you have to hold vehicle speed above 1200 rpm,s to time it. Have you done a tune up on it ? Are you getting a check engine light now ?
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
GrayHeadedMule
Jul 9, 2013 10:16 PM
Big C
Sep 2, 2011 4:39 PM
Shutterbug
Nov 29, 2008 5:52 AM
