99 silverado won't start
Old Apr 23, 2012 | 3:39 PM
chrisfuller01's Avatar
Default 99 silverado won't start
driving home and it just died with out any warnings at all. New battery, new starter, checked all fuses. Ignition module and coil both tested good. Not getting any power what so ever. Any suggestions would be greatly appreciated.
Old Apr 23, 2012 | 6:39 PM
evans906's Avatar
Default Re: won't start
Is the check engine light on? Did you check the ground wire at the battery? Did you clean the battery terminals? Did you check the battery positive wire?
Old Apr 23, 2012 | 7:47 PM
Does it do anything when you turn the key? Anything light up? If not evans could be right about bad ground.
Old Apr 23, 2012 | 10:06 PM
Doug Roberts's Avatar
Sifter safety relay or security
Old Apr 24, 2012 | 6:55 AM
No the check engine light is not on. everything with the battery has been checked and clean. When the key is turned on nothing happens. No clicking, no lights. The door doesn't even ding when opened.
Old Apr 24, 2012 | 11:36 AM
Did you check to see if the ignition switch is turning on the power?
Old Apr 24, 2012 | 11:48 AM
Thanks for your help everyone. We've been told to try and change the ignition switch by another person. Is there a way to check to see if there is power coming from the ignition switch?
Old Apr 24, 2012 | 7:38 PM
evans906's Avatar
you might check the IGN 40amp fuse and the starter relay which both are in the underhood fuse/relay center. I think there is a crank 10amp fuse which is on the left side of the dash. good luck
Old Apr 24, 2012 | 7:57 PM
You can also check the starter solenoid wire to see if it gets 12 volts with the key turned to start. With all the fuses being good there should be power there with the key at start.
ZChevyAK
Nov 13, 2015 6:45 PM
bracca
Jul 12, 2009 6:14 PM
FamilyOf5
Jun 11, 2008 2:56 PM
montuckyz
Jan 28, 2008 12:48 PM
