abs brake issue: 05 silverado
Old May 12, 2015 | 11:46 AM
tyafrya's Avatar
New User
Awaiting E-mail Confirmation
Default abs brake issue: 05 silverado
ABS activates under 10 mph. No ABS light (Code: left ft. brake sensor.) Ran the gamete" cleaned sensor seat, chassis grounds by OBCM and finally replaced Ft. bearing assy. Problem still exists. Unplugged left ft. ABS sensor, (for "safety") problem gone. I'm 60 yrs. old! remember no seat belts or abs. Bias ply tires, steel bumpers, drum brakes, single cyl. master brake cyls. and the speed limit was 70 mph.! Enough of that, I still would like to get the abs system to work. Doe's anyone have any thoughts? Could it be the obcm?
Old May 12, 2015 | 8:15 PM
you are getting a false abs activation.
if the abs light is on there must be code set in the ebcm. unplugging a speed sensor will turn the abs light on, set a dtc and disable the system.
Old May 15, 2015 | 7:32 AM
tyafrya's Avatar
New User
Thank you for your reply tech2. If I'm getting a false abs activation what could possibly cause it?. The computer threw a code to indicate left ft. wheel sensor but my abs light has never come on,...... well.... not until I unplugged the wheel sensor.
Old May 15, 2015 | 7:59 AM
the code will be set in the ebcm not the pcm. you will need a full function scan tool to read abs dtc.
find out what the code was before you disconnected the abs harness.
Old May 15, 2015 | 5:14 PM
tyafrya's Avatar
New User
10-4 tech2 , thank you.
its.all.hers.chevy
Oct 22, 2014 9:18 AM
cmcbride
Avalanche
Aug 8, 2012 3:12 PM
Thad W. Posey
Jun 15, 2012 9:21 AM
primesuspect
Oct 13, 2011 9:53 PM
mjjv
Aug 12, 2008 11:08 PM
