AC Problem or Not
Not sure if I have a problem or not. I have a 2005 Silverado 2500 HD Ext cab. My AC unit seems to constantly cycle on and off. You can feel the compressor clutch kick in for about 3-4 seconds and then dissengage. So I get a burst of cold air and then semi-cold air over and over. Is this normal operation? I also get much colder air when going below 50 mph. For example on the drive to work today, temp was 100. Cooling was ok driving at 60-70 mph. Slowed to pull into parking lot and temp from AC must have dropped by about 10-15 degrees. Air was extremely cold. Could this be due to fan clutch on the engine disengaging at higher speeds? Is this all proper operation?
Maza Mike
Avalanche
Dec 12, 2014 12:08 AM
krustyjonez
May 17, 2011 8:02 PM
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
