AC Problem or Not
Old Jun 25, 2010 | 3:56 PM
schristi69's Avatar
Default AC Problem or Not
Not sure if I have a problem or not. I have a 2005 Silverado 2500 HD Ext cab. My AC unit seems to constantly cycle on and off. You can feel the compressor clutch kick in for about 3-4 seconds and then dissengage. So I get a burst of cold air and then semi-cold air over and over. Is this normal operation? I also get much colder air when going below 50 mph. For example on the drive to work today, temp was 100. Cooling was ok driving at 60-70 mph. Slowed to pull into parking lot and temp from AC must have dropped by about 10-15 degrees. Air was extremely cold. Could this be due to fan clutch on the engine disengaging at higher speeds? Is this all proper operation?
Old Jun 25, 2010 | 11:14 PM
Flying Low's Avatar
Ride of the Month
May 2008
From: Millbrook,Alabama...Slap dab in the middle of God's country
Sounds like it is low on freon, cutting out on low pressure as soon as compressor engages.
Have it checked for leaks and refilled.
Old Jul 6, 2010 | 11:29 AM
schristi69's Avatar
Took it in for service and truck is like a refrigerator now, Was low on freon.
Maza Mike
Avalanche
Dec 12, 2014 12:08 AM
Xerklite
Apr 27, 2013 9:14 AM
krustyjonez
May 17, 2011 8:02 PM
ezzyboy954
Feb 9, 2011 12:12 PM
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
