Add Cruise to 2004 2500HD
Old Jun 5, 2009 | 9:12 AM
FE Knucklebuster's Avatar
Default Add Cruise to 2004 2500HD
New user to the forum.
I just picked up a 2004 2500HD without cruise and I would like to add it. I seem to remember hearing something about longer wires being needed for units on the 2004 and up pickups. Is this right? or can I pull a unit off a 2003 and it work without any alteration? Thanks
Old Jun 13, 2009 | 10:01 AM
jeepzz's Avatar
I have a 2003 HD that didn't come with cruise and I too would like to add it. My combo turn signal switch is giving me problems so I've been try to research adding cruise. I've read about adding in the 4 required wires but it didn't specify what years needed the wires (just 03-06 in general). ARe you saying that the 2003 is just a simple plug in combo switch swap? That'd be great, if you can, let me know what info you have. Thanks in advance.
Old Jun 14, 2009 | 5:44 AM
I got a junkyard cruise/wiper switch from an '03 Silverado. Pulled my dash cover and steering housing cover and found the 4-pin plug receptor already installed as part of the factory harness. No cutting or soldering needed. Just plugged everything back in and I has cruise. Took about 30 minutes from start to finish. Ended up being a LOT easier than I was told.
Old Jun 15, 2009 | 8:24 PM
jeepzz's Avatar
If it's only 1/2 hour's work, I'll pull my covers to see if the 4 pin connector is there. Thanks for your help.
Old Jun 18, 2009 | 5:10 PM
jeepzz's Avatar
I installed my new switch in a snap. My cruise work perfectly, I didn't even know that there was a cruise indicator light on my dash panel until I activated it. Thanks for the info.
Old Jun 19, 2009 | 4:56 AM
Good going. It's like getting an unexpected gift when you find that receiver plug and it all works flawlessly.
mossyoak
16
Apr 12, 2023 8:40 AM
shoveljockey
Jul 17, 2011 5:19 PM
tkdunn
Jun 20, 2010 11:15 PM
shakeypete
Feb 13, 2008 8:25 AM
AviD
Jun 26, 2007 10:41 AM
