Add Cruise to 2004 2500HD
New user to the forum.
I just picked up a 2004 2500HD without cruise and I would like to add it. I seem to remember hearing something about longer wires being needed for units on the 2004 and up pickups. Is this right? or can I pull a unit off a 2003 and it work without any alteration? Thanks
I have a 2003 HD that didn't come with cruise and I too would like to add it. My combo turn signal switch is giving me problems so I've been try to research adding cruise. I've read about adding in the 4 required wires but it didn't specify what years needed the wires (just 03-06 in general). ARe you saying that the 2003 is just a simple plug in combo switch swap? That'd be great
, if you can, let me know what info you have. Thanks in advance.
I got a junkyard cruise/wiper switch from an '03 Silverado. Pulled my dash cover and steering housing cover and found the 4-pin plug receptor already installed as part of the factory harness. No cutting or soldering needed. Just plugged everything back in and I has cruise. Took about 30 minutes from start to finish. Ended up being a LOT easier than I was told.
mossyoak
16
Apr 12, 2023 8:40 AM
shoveljockey
Jul 17, 2011 5:19 PM
tkdunn
Jun 20, 2010 11:15 PM
shakeypete
Feb 13, 2008 8:25 AM
