Air Lift Siverado
Old Aug 3, 2011 | 6:18 PM
sapper3's Avatar
Default Air Lift Siverado
I have a 2004 Chevrolet Z71 4x4 Extended Cab. I want to stiffen up the suspension for towing my 18ft Crestliner and ATV. I want to know if the frame is different between a Silverado and my 1500 Silverado? The reason is I purchased the LOAD LIFTER 5000 by Air Lift and it says not recommended for the Silverado. I believe it is only because the Load Lifter 5000 will allow a person to haul that much weight and the truck is not rated for that. I don’t plan to haul that I will stay with in the 2000lb rate ( as per the Air Lift for my truck). I did not purchase the Ride levelers for the 1/2 ton because they looked weak? So in the end the question is there a frame size difference between the Silverado HD and the 150 Z71 Silverado? The LOAD LIFTR are fr a Silverado HD. Thanks <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Aug 6, 2011 | 9:12 AM
sapper3's Avatar
Question
I find ithard to believe no one on this forum can nswer this question. Can any one help me out?
Old Aug 7, 2011 | 8:01 AM
Gnhntn's Avatar
Default There is a difference
Take a look at the frame of a 2500HD and you will see it is a lot heavier then the 1500, it is very easy to see the difference in them. All you have to do it look at it in the rear wheel well. I have had a 2500HD and currently have a 1500.
sclserviceCHAMBERS
Mar 28, 2015 8:29 AM
Kevino1402
Jul 25, 2014 9:09 PM
Dopeoperator
13
Sep 7, 2010 10:35 PM
PeteyG
Jan 10, 2009 10:11 PM
wildonev1
Sep 10, 2006 12:36 AM
