Battery drains over 24 hours
Old February 6th, 2022 | 5:40 PM
Syncman's Avatar
Default Battery drains over 24 hours
2004 1500 silverado
Constant current draw from battery. 0.5A. pulled fuses till it went away. IPC/IDC fuse. Occasionally the instruments will go dead, then come back while driving. Also the security/theft light will flash occasionally, which is not available on my 2004. The cluster was replaced in 2005 under warranty. Do I have to replace the cluster?
Old February 6th, 2022 | 8:40 PM
problem could be the cluster, or anywhere in the wiring harness between the fuse block and the cluster. You'll have to use a meter and schematic to probe for the fault.
Gregory Dunican
May 24th, 2021 11:05 PM
jrod3030
December 7th, 2020 7:18 AM
Joe A
April 28th, 2019 1:23 PM
thisizit32
May 8th, 2018 2:56 PM
strifecr
October 9th, 2014 9:41 PM
Quick Reply: Battery drains over 24 hours
