Where to get instrument cluster repaired?
Old Dec 5, 2020 | 2:11 PM
jrod3030's Avatar
Default Where to get instrument cluster repaired?
I have a 2001 Silverado and the battery kept dying, thought maybe bc of corrosion but there was none. Unplugged the cluster and it’s still got battery juice so I need to get the cluster repaired. Any recommendations on where to get it done and how much? I’ve seen listings on eBay for 50-75 dollars. Just need it repaired to sell the truck. Not going to keep it.
thanks!
Old Dec 5, 2020 | 2:40 PM
kevinkpk's Avatar
thanks!
You will have to take it or ship it as the odometer has to stay with the truck. I had mine repaired locally. You can google instrument repairs for this in your area.
Old Dec 6, 2020 | 7:29 AM
How long does it take for the battery to die? Does the battery test good? Why do you think the cluster is at fault?
Old Dec 6, 2020 | 10:39 AM
ipc repairs shops usually only fix bad steppers motors and mosefet transistors for the display. you may want to go with a replacment cluster for a parasitic draw. there is a cluster vendor on this site; see what they think.
Old Dec 6, 2020 | 1:16 PM
jrod3030's Avatar
at the ipc repair website? Or was there another link you provided that isn’t showing?
Old Dec 6, 2020 | 1:18 PM
jrod3030's Avatar
takes 2-3 days, it’s a spare vehicle but if I were to drive it every other day it’s fine, but if not it dies. I unplugged the cluster and left it sitting for over a week and started up like a champ. So right now I leave the cluster unplugged when it sits.
Old Dec 6, 2020 | 6:32 PM
dand d instrument cluster in the vendor directory under the marketplace link or the advert window on the the right of the screen. i have not used them but i am sure they are capable
Old Dec 7, 2020 | 7:18 AM
hanky's Avatar
You might want to check out ,
Module Master
1-888-892-0764
jrod3030
Oct 31, 2020 10:40 AM
Subhuman
Jun 28, 2020 4:42 PM
Racer04
Feb 28, 2019 9:27 AM
Steve_Suburban
May 2, 2016 4:19 PM
jpskperry
Mar 1, 2013 1:43 PM
