brake problem???????
Old Nov 24, 2008 | 9:29 PM
steve71100's Avatar
Default brake problem???????
i have a 96 silverado and the brake pedal almost goes to the floor when the brakes are applied. i have been told that it may be the booster. i could pump the pedal 1 time and have a good pedal, but today it takes 3-4 pumps to get good brakes. i don't see any fluid and the level is good. do you think it is more likely to be the booster or the master cylinder? any help, suggestion, or tips will be greatly appreciated!!!!
Old Nov 25, 2008 | 9:31 PM
jkgray80's Avatar
Default RE: brake problem???????
Master cylinder was a very common problem on those. Bleed off booster (engine off, pump pedal couple times) then try hitting the pedal hard & fast once. If it stops higher than normal the master cylinder is for sure the problem. Also check adjustment of rear brakes & hoses for swelling.
Slobby Baymon
Nov 12, 2013 11:52 PM
cmcbride
Avalanche
Aug 8, 2012 3:12 PM
Thad W. Posey
Jun 15, 2012 9:21 AM
tom5170
Mar 19, 2010 11:57 PM
