A/C split system blowing hot air
Old Aug 29, 2009 | 10:12 PM
gregoryboen's Avatar
Default A/C split system blowing hot air
2005 1500 4wd Z-71. I had to disconnect the negative cable from the battery to replace a fuel injector and after that when I run the a/c, the driver side blows cold air ok but the passenger side is blowing hot air no matter where the temp slide is located. No other connections were broken while working on the fuel injection system. Any ideas?
Old Aug 31, 2009 | 11:18 AM
oih82w8's Avatar
Sounds like the heater bypass door in the plenum is disconnected, jammed, or you may have a critter nest.
Beebe
May 3, 2019 7:37 AM
Farmerluke
Jun 25, 2013 8:13 AM
eddie33m
Oct 31, 2012 11:07 AM
cdbrock24
Apr 26, 2011 12:02 PM
larryboy58
May 23, 2010 5:50 PM
