Cabin fan, no workie till position 3-4 and 5. why come?
Old Apr 1, 2012 | 9:24 PM
JoeBlow's Avatar
Default Cabin fan, no workie till position 3-4 and 5. why come?
I am looking at a 2001 Silverado in very nice condition.
The cabin fan (heat, A/C) doesn't work till you turn it all the way up.
Is this a control issue at the switch, somewhere else, or the fan itself?
How hard is it to replace?
Thanks.
Old Apr 1, 2012 | 9:58 PM
It is probably the fan motor resister. It is located under the dash by the blower motor.
Old Apr 2, 2012 | 3:42 PM
chevyboy1993's Avatar
fan motor resistors. they're like 30 bucks at an auto parts store. alot of gm's have that problem 96+ years
Old Apr 2, 2012 | 4:32 PM
grumpychevy's Avatar
Proper name when you get to the parts store is blower motor resister.
Old Apr 10, 2012 | 5:16 PM
JoeBlow's Avatar
Can anyone give me any info on replacing it?
For example, where it is. How much digging required to get to it etc.
My truck has the remote Cassette Tape unit mounted below the dash in the upper half of the center console. I need to reattach the power lead to it which was cut and used in an aftermarket radio installation. I want to use it to run my iPod. So, I will be tearing into that section of the truck and I may as well do both at once.
Old Apr 10, 2012 | 6:42 PM
It is under the dash on the right side behind the glove box. You have to remove a cover underneath the dash first.
Old Apr 10, 2012 | 7:14 PM
JoeBlow's Avatar
OK Found it, changed it. Fixed it.
That mother gets HOT! No wonder it failed.
Thanks for the info.
xeqshnr
HHR
22
Feb 13, 2015 9:18 AM
Hunduh
Aug 3, 2011 10:09 PM
