Old Jul 24, 2015, 6:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community expertsBrowse all: Engine and Powertrain
Print Wikipost
Can I add water to my coolant?
Old Jul 5, 2010 | 10:24 PM
tom5170's Avatar
Default Can I add water to my coolant?
My radiator cap was loose and almost half the coolant shot out of it when the engine warmed up. I added some water in hopes of making it through the day tomorrow at work before I can drain the radiator and add fresh coolant.
Old Jul 5, 2010 | 10:51 PM
LARIDERS's Avatar
that should be fine for now. just make sure to remix it to a 50/50 and fill it up the right way soon. The only real danger in putting water in, is it getting cold and freezing. that would crack the block.
Old Jul 6, 2010 | 2:14 PM
therewolf's Avatar
Hi tom5170,
Welcome to the Chevy Forums.
In the event that you added less than half a gallon of water, you shouldn't have to change anything, for now. That much difference in the 50/50 ratio isn't really going to make much of a difference, unless you live high in Northern Canadian Lattitudes.
XmoDDeR
Mar 12, 2008 9:21 PM
6pac
Nov 29, 2007 5:25 PM
shayandude
Oct 9, 2007 8:12 PM
tracyballard
Jan 29, 2007 3:09 AM
