cant figure out this goes
im rebuilding my first trans, its 4L60 E. i have almost back together but i cant figure out where this one peice goes. any help? its an alost green color and very light
Governor pressure screen on a 4L60; force motor screen on a 4L60E. Lives in a channel recess, in the case under the spacer plate. If you can't find the recess, I'll go rumage around and see if I can find you a picture.
Aren't ya glad ya yanked that valve body?![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
Allan
Allan
Okay,
Can I give ya a hint without ya getting mad? When taking a picture, make sure the light source is behind you.![Wink](https://chevroletforum.com/forum/images/smilies/wink.gif)
So, what you are holding is the 3-2 control valve. Goes in the bore behind the 3-2 control solenoid. Spring in first, then the valve and finally the solenoid.
Allan
Allan
Yes Sir,
If my feeble old memory serves me correctly.![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
GM did a design change between 1995 and 1996 models. Guess I was just assuming you were working on the later?
Look in the bore. And, just like the TV Postal ad says; If it fits, it ships.![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
Allan
Allan
Okay, there ya go.
First bore inboard of the manual valve, forward end of the valve body. That valve goes skinny end in first (after the spring).
Then the solenoid; and it's keeper is snapped in back aways in the valve body.
Allan
Allan
SIVAONES
April 2nd, 2011 7:47 PM
tboz
May 21st, 2010 9:08 PM
