cant figure out this goes
Old Jul 8, 2012 | 10:37 AM
isrummell's Avatar
Default cant figure out this goes
im rebuilding my first trans, its 4L60 E. i have almost back together but i cant figure out where this one peice goes. any help? its an alost green color and very light
Old Jul 8, 2012 | 11:11 AM
Allan In NE's Avatar
Governor pressure screen on a 4L60; force motor screen on a 4L60E. Lives in a channel recess, in the case under the spacer plate. If you can't find the recess, I'll go rumage around and see if I can find you a picture.
Aren't ya glad ya yanked that valve body?
Allan
Old Jul 8, 2012 | 11:56 AM
isrummell's Avatar
its not a screen. its like a piston
Old Jul 8, 2012 | 12:29 PM
Okay,
Can I give ya a hint without ya getting mad? When taking a picture, make sure the light source is behind you.
So, what you are holding is the 3-2 control valve. Goes in the bore behind the 3-2 control solenoid. Spring in first, then the valve and finally the solenoid.
Allan
Old Jul 8, 2012 | 1:25 PM
isrummell's Avatar
are u syre? the rebuild maunal i have doesnt show anything like that there. it shows the solenoid then a plug with a spring under it
Old Jul 8, 2012 | 1:27 PM
isrummell's Avatar
there a better pic
Old Jul 8, 2012 | 3:14 PM
Yes Sir,
If my feeble old memory serves me correctly.
GM did a design change between 1995 and 1996 models. Guess I was just assuming you were working on the later?
Look in the bore. And, just like the TV Postal ad says; If it fits, it ships.
Allan
Old Jul 8, 2012 | 4:48 PM
isrummell's Avatar
its a 98.
Old Jul 8, 2012 | 5:09 PM
Okay, there ya go.
First bore inboard of the manual valve, forward end of the valve body. That valve goes skinny end in first (after the spring).
Then the solenoid; and it's keeper is snapped in back aways in the valve body.
Allan
SIVAONES
Apr 2, 2011 7:47 PM
tboz
May 21, 2010 9:08 PM
SEGaudette
Camaro
Dec 7, 2008 9:17 PM
19899c1
Jan 22, 2008 2:36 PM
AstrosRule
Jul 9, 2007 3:36 PM
