Carb problem?
Old Apr 7, 2007 | 2:04 PM
bowtieguy's Avatar
Default Carb problem?
I have a 85 Silverado 2-wheel drive w/ a four barrel quadrajet - has experienced starting problems.Engine starts but races at high rpm. Replaced electronic choke control and this helped the racing problem a bit. Replacedcam in butterfly, installed new carb kit. Engine still runs very ragged and at low rpms, it backfires terribly. Any ideas about what my next step should be?
Old Apr 7, 2007 | 6:57 PM
kcb37's Avatar
Default RE: Carb problem?
Check your vacum lines, you should have some on the carb, if they are leaking that would make it run funny. You may want to check your timimng too. That is probably not the cause but it may help.
Newt
Jun 8, 2011 2:45 PM
icedtepe
Mar 30, 2010 10:09 AM
83Silver
Jul 5, 2007 6:12 PM
chubs350
Feb 28, 2006 12:24 AM
