Cargo Stop Light 99 Silverado
Old Mar 25, 2010 | 4:47 PM
Brucgraham's Avatar
Default Cargo Stop Light 99 Silverado
My cargo brake light "on the cab" does not work. The silverado has realitivly low miles, 61000 and in very good shape. I just got it and discovered the cargo brke lights do not work. I changed the bulbs with no luck. The white cargo lights work fine. The brakes lights on the box work fine. Has anyone had this problem or does anyone have any ideas?
Thanks
Brucgraham
Old Mar 25, 2010 | 8:50 PM
s34n's Avatar
is there a separate fuse that hasnt been checked?
Old Mar 26, 2010 | 6:14 AM
Brucgraham's Avatar
Default I checked the fuses
I checked all the fuses, however I did not see a specific fuse for that system. All the fuses seemed to be OK
Old Mar 26, 2010 | 7:18 PM
s34n's Avatar
have you put a volt meter on the contacts to see if its getting power?
Old Mar 26, 2010 | 8:42 PM
old dog's Avatar
Default light
there should be a chismal fuse i believe in the fuse panel on the end of the dashboard .
Old Mar 28, 2010 | 9:41 AM
Brucgraham's Avatar
Default Fuses-meter
I visually checked the fuses on the side of the dash. Checked OK. I am looking for a meter to check power at the bulb. I do know there is power at the light assembly because the white cargo lights work fine.
Old Apr 14, 2010 | 6:18 PM
Brucgraham's Avatar
Default Got it Fixed !
After confirming I had power to the brake light assembly I reliazed that the bulds were not making contact with the brass assembly. Everything was clean and looked new. I wounder if these lights ever did work.I replaced the light assembly and everything works great.
Thanks for the help
Brucgraham
Mojotics
Sep 2, 2020 4:23 PM
marine02xx@yahoo.com
Jan 28, 2014 5:33 PM
Classical Glass
Aug 16, 2010 2:25 PM
Mille Racer 69
Mar 15, 2010 8:08 PM
jap904
Sep 4, 2008 5:27 PM
