Old Jul 24, 2015, 5:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community expertsBrowse all: Engine and Powertrain
Print Wikipost
Change oil soon light
Old Aug 25, 2011 | 3:35 PM
Flipg8tor's Avatar
Question Change oil soon light
How do you reset the oil change reminder light. I have changed the oil and need the sequence to reset the reminder.
Old Aug 25, 2011 | 3:48 PM
birdie's Avatar
for my truck i just cycle through the trip panel until it shows the oil change notice, then just hold down the button.
Old Aug 25, 2011 | 3:49 PM
kevinkpk's Avatar
Turn the key on (not running), hit the accelerator pedal 5 times within 3 seconds.
Old Aug 25, 2011 | 8:47 PM
MDTAHOE's Avatar
Professional Mechanic
What year? What kind of truck?
Old Aug 26, 2011 | 8:53 AM
kevinkpk's Avatar
I'd suggest if you don't have one, get an owners manual for it.
Old Aug 31, 2011 | 11:56 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> How do you reset the oil change reminder light. I have changed the oil and need the sequence to reset the reminder.
Outbound:
On page 486 of the owners manual it says to:.
1. Turn the ignition key to RUN with the engine off.
2. Fully press and release the accelerator pedal three times within five seconds.
If the OIL LIFE RESET message displays for 10 seconds, the system is resetting.
3. Turn the ignition key to LOCK.
If the CHANGE ENGINE OIL message comes back on when you start your vehicle, the engine oil life system has not reset. Repeat the procedure. If it still does not reset, see your dealer for service.
Breanne
Chevrolet Customer Assistance
Old Sep 1, 2011 | 10:55 AM
Flipg8tor's Avatar
Default many thanks.
Appreciate the help very much. It's annoying to have that reminder on all the time. Worked great.
texasdontholdem
Jan 4, 2011 2:26 AM
Toby T
Mar 14, 2008 5:16 PM
digdug
Feb 4, 2007 3:08 PM
kimoZ71
Dec 12, 2006 10:36 PM
hopkinstx
Sep 17, 2006 12:29 AM
