Last edit by: IB Advertising
Browse all: Wheels and Tires
- Chevrolet Silvreado GMT800, GMT900, K2XX How to Change Tire
Change rim size
#11
Well I disagree on that cause it depends on what kind of wheels you are getting, not all alloy wheels are made the same way = not all of them weigh the same as the stock ones!!!!!!!
Plus you don't really get the same mpg with just any wheel-tire set up unless they really weigh the same and are the same over all size.
On the other hand it is harder for you to turn a truck wheel than it is a bicycle one, even though the big wheel covers more terrain than the small one, thus there has to be a balance, in other words: "engine horse power+wheel size+tire weight+wind+truck weight+road conditions+driver habits etc. etc. etc.= mpg"
About removing the TPMS fuse, I don't know b/c that might trow a code at time of inspection but I might be wrong, maybe someone else can answer that.
In conclusion yes you have to pay to look good, or otherwise stay with stock and look just like another truck on the road!!!
#12
TPMS will never throw a code because it is only a pressure transducer in the valve stem and a antennae in the dash that activates the light. If you remove the fuse then the antennae cant turn on the light.
The tire size has nothing to do with mileage, it will compromise driveability and may throw off the speedo. If the car weighs 5320 lbs. with 17" and is shaped like a brick, the tires have little to do with mileage. All you gain from a larger tire is better appearance and like I said the ability to literally cover more ground with each revolution. This allows you to cover more distance at a lower Engine RPM in the same gear.
I didnt understand the bicycle tire example, because every SUV I see since maybe 1969 has power steering.
Dee74
July 24th, 2010 11:40 PM
