Changed battery, now radio won't power on
Old Jul 27, 2015 | 2:49 PM
brain1961's Avatar
Default Changed battery, now radio won't power on
In my 2007 Silverado Classic, my battery went dead so I had to have it changed. Ever since then, my radio will not turn on and shows no sign of power (it did work before the battery change). A little background, the radio is not the OEM radio, it is a Pioneer double din DVD unit. If I put the OEM unit back it, it works fine. Since this has happened, I've had the Pioneer exchanged twice thinking it was a bad unit but it still does not work. I have changed out the wiring harness, I've had it checked out to verify it is correct. I have checked and even replaced the radio fuse in the fuse box under the hood.
Is there anything in the security system that could prevent it from working?
I'm stumped and hope maybe someone has other ideas to check out.
seamorewatervip
Jan 14, 2013 6:13 PM
kalama3
Dec 31, 2010 7:52 PM
knucklebust
12
Jan 17, 2010 4:53 AM
Macross707
Sonic (Aveo)
Jul 8, 2009 7:01 PM
larry_chip
Apr 24, 2007 11:46 AM
