clunking in front left wheel
Old Apr 23, 2009 | 12:06 PM
  #11
chadt256's Avatar
how in the crap can i get this bolt off everyrthing twist lol and i have nothing to go around the top of it
Old Apr 24, 2009 | 10:18 AM
  #12
steamer808's Avatar
What I meant was the shock was just loose so they tightened the top bolt, problem solved.
Old Apr 24, 2009 | 6:02 PM
  #13
DeeZ's Avatar
Ride of the Month
August 2009
Originally Posted by chadt256
i cut the bump tops off because they would hit if i did go over a bump but this issue just started im pretty sure its a bushing.. never have replaced one before.. pretty hard?
You cut your bump stops off?! Yikes. Your arm is supposed to hit the bump stop when going over bumps and such, that's what they are there for - To keep your truck from completely bottoming out and either blowing the shock or a ball joint. Or am I missing something?
Deez
Old Apr 24, 2009 | 6:05 PM
  #14
DeeZ's Avatar
Ride of the Month
August 2009
Try and get a grip on the shock body itself with your hand, you should be able to keep the body from moving that way when trying to loosen the nut it doesn't take much. But aren't you trying to tighten it since it may be the cause of your clunking sound?
Deez
ericconn
Jun 19, 2012 9:56 AM
RomanGuzi
Oct 2, 2011 11:40 AM
litcatp
Jun 4, 2009 1:44 PM
derekf
Apr 24, 2009 9:57 PM
avoyager
Apr 21, 2008 9:11 PM
