Code 35 will NOT go away!!!
Old Aug 28, 2011 | 8:49 PM
makingaZJ's Avatar
Default Code 35 will NOT go away!!!
Code 35 is for the IAC valve. I have replaced the valve itself, the harness that plugs into it and cleaned up the grounds on top of the upper radiator hose on my 4.3L.
The "cure" for a code 35 is just supposed to be (replace IAC).
Im just short of getting a new ECM.
Any help before I hopefully dont waste some more money??!!
Old Sep 1, 2011 | 6:47 PM
loosebearing's Avatar
Did you do a relearn on iacv? Also clean port good where iacv goes .. may have some gunk not letting pentel work right.
Old Sep 1, 2011 | 7:16 PM
kevinkpk's Avatar
Don't throw your money on an ecm, sensor or needs cleaning ect.
Old Sep 5, 2011 | 6:47 AM
makingaZJ's Avatar
Default Resolution
I forgot to mention that i had my intake manifold gasket rerplaced, the mech that did it DID NOT tighten down my distributer when he put it back in. so through a chain of sequences it was the timing.
deepstuff
Apr 27, 2012 5:43 PM
Yankeecorvette
Dec 30, 2008 10:41 PM
cowboyfromhell
Jun 5, 2007 9:31 AM
cad
Mar 20, 2007 2:37 PM
