code 43
Old Jun 16, 2014 | 11:08 AM
Tman6648's Avatar
Default code 43
Code 43 is the electronic spark control circuit. Recently I had to replace the leaking heads on my truck, I was having problems passing the CA emission test. I replaced the following: coolant temperature sensor (CTS), Electronic spark control knock sensor (ESC), Electronic spark control module (ESC), The distributor (complete), Exhaust gas recirculation valve (EGR), Manifold Absolute pressure sensor (MAP), Exhaust Oxygen sensor (O2), Throttle position sensor (TPS), Idle air control (IAC), the PVC, and plugs and wires.
I replace all of the sensors related to the emissions and some that while breaking down the top end of the motor I accidently broke (Knock Sensor). I set the timing with the ECM unplugged to zero. The problem I am having is the code 43 that keeps coming up when I am driving and put the motor under any stress it pings and the check engine light comes on and the truck starts to hesitate when I am starting off and running bad. Can Anyone help? I am at the end of my rope.
Donthaveone
Aug 27, 2013 9:45 PM
Vinna
Nov 12, 2012 8:51 AM
timT
Nov 21, 2011 10:29 PM
T'boo Ted
Oct 28, 2010 5:15 PM
tshunt01
Feb 19, 2007 12:26 AM
