Crank the keys?
Old Nov 17, 2012 | 9:53 PM
BigRed922's Avatar
Default Crank the keys?
Should i just crank the stock keys or buy a leveling kit? Is there any differece between stock and new keys?
Old Nov 18, 2012 | 8:47 PM
country_09's Avatar
Levelin keys are reindexed for more lift. That's the only difference. If your bars aren't saggin, just crank stock keys
Old Nov 18, 2012 | 9:42 PM
Southerncadillac's Avatar
you can also try putting ford keys in, ive heard people getting 3 inches out of them
Old Nov 19, 2012 | 11:34 AM
BigRed922's Avatar
how many inches can i get out of stock? and will i be able to fit 285/75-16?
Old Nov 19, 2012 | 4:18 PM
country_09's Avatar
2" or so. Ad you could fit that with no levelin kit
Old Nov 19, 2012 | 5:09 PM
you should be able to fit those without a leveling kit or cranking the keys, if you want the front end raised a bit and dont mind a little bit stiffer of a ride to the keys but if you dont mind spending a little extra for a nicer ride go with the leveling kit
Old Nov 19, 2012 | 8:08 PM
country_09's Avatar
Common misconception. Levelin kit doesn't give you a smoother ride. Crankin stock keys all the way up is a much better ride than crankin a levelin kit. Levelin keys are reindexed and allow for more crank, leavin less room between the upper arm and the droop stop. Suspension bottomin out and horrible tie rod/ball joint/ cv angles
Old Nov 19, 2012 | 10:24 PM
BigRed922's Avatar
thank you guys, im gonna be ordering my new tires and wheels soon and want to raise the front end up to make it look good. last question, do i need shock extensions if i crank the keys up? iv heard yes and no
Old Nov 20, 2012 | 5:34 AM
grumpychevy's Avatar
I cranked my keys up and did need extensions. My old shocks were extended all the way out and my truck rode like a hay wagon. I replaced my shocks with Rancho's in the stock length (takes any guess work out of it) and bought extensions off of eBay for about $25. This was money well spent. Rides like a truck again instead of a hay wagon.
Fishinfooleric10@aol.com
Oct 11, 2012 11:47 AM
skillettxxx
Jan 6, 2008 6:31 PM
beasterd
Cobalt
Oct 26, 2007 11:55 AM
goat19642004
Apr 9, 2007 2:30 PM
doo600
Dec 22, 2006 7:59 PM
