Dual Batteries / Battery Isolator / Power Inverter / Subwoofer
Old Apr 8, 2014 | 7:13 PM
keybler's Avatar
Default Dual Batteries / Battery Isolator / Power Inverter / Subwoofer
Hello all, This is my first post. Maybe the information is already on this forum but I can't located it.
I want to run a 3500 watt power inverter and also have 2x 1000 watt amps to run 2 subwoofers. The audio aspect of this question can be left out. Lets also assume that I will not run the inverter and the amps at the same time.
I'm thinking of adding a second battery to the truck and using a battery isolator with a switch to switch aux to main if I end up with a dead main battery.
The big question is do I need to have a bigger alternator to keep pushing enough power to 2 batteries?
2005 Silverado 4.3v6 Base model standard cab.
Thanks!
Old Apr 10, 2014 | 12:13 AM
jumpshowhigh's Avatar
Thanks!
Your stock alternator should be fine. Add a Perfect Switch Dual Rectifier with a battery combine switch along with a secondary battery that attaches to the inverter, and you should be golden.
ve4aaz
Sep 23, 2024 6:42 PM
73K20
Aug 6, 2010 10:09 AM
JayDougherty
Jul 12, 2007 11:58 PM
TexasTahoe
Oct 6, 2006 6:42 PM
