Factory 20" rims
Hi all, i am new to the forum.
I have a 2007 Chevrolet 1500 with factory 20" rims. I am having some issues with the tires not holding air. I took it to a tire shop and once they removed the tires from the rims, they found that every rim was corroding really bad on the inside edge causing the tires to lose air. Has anyone else had issues with factory rims corroding really bad? Is there anything i can put on the rims to stop them from corroding? Are the rims covered under warranty? Thanks everyone for your assistance!
Trevor
Trevor
Professional Mechanic
Any chrome rim will eventually do it. How fast depends on how much moisture has been in the air used to inflate the tire. You can remove the tires and sand the rims (beads) it will help for a while. If you have them filled with nitrogen there will be no moisture.
damone
May 8th, 2021 12:36 PM
Platinum
January 16th, 2019 9:53 PM
Keesie
November 15th, 2013 4:46 PM
For Sale: IROC 20"22"24"26" W.TIRE pkg
chevyman323
July 16th, 2010 11:56 AM
