fan is making a squealing noise
Old Mar 24, 2010 | 7:43 PM
TexanKing's Avatar
Default fan is making a squealing noise
like the title says my fan is making a creaking squealing noise, any tips or ideas on what i can do to fix this. when i push on the accelorator the noise increases. I know its the fan cause when i turn the engine off everything stops but the fan keeps spinning and the noise continues until the fan stops spinning.
Old Mar 24, 2010 | 7:59 PM
cam3439's Avatar
Is this an elec. fan or a mechanical fan? It sounds like a mechanical fan, and sounds like the clutch is shot. That I know of, your fan shouldn't be spinning after the engine shuts off. Have you noticed any overheating?
Old Mar 24, 2010 | 8:02 PM
TexanKing's Avatar
Default Fan making noise.
Fan making a squealing/squeaking noise. any idea how to fix this. its a '97 Silverado 4.3L C1500.
Old Mar 24, 2010 | 8:04 PM
nauticstar87's Avatar
New belt possibly.
Old Mar 24, 2010 | 8:06 PM
TexanKing's Avatar
not over heating and its the fan right behind the radiator.
Old Mar 24, 2010 | 8:41 PM
MDTAHOE's Avatar
Professional Mechanic
Since it still does not when you shut the truck off, replace the fan clutch. The fan should stop spinning with in 1-2 seconds after turning the engine off
Old Mar 24, 2010 | 8:47 PM
TexanKing's Avatar
how do i replace the fan clutch?
Old Mar 24, 2010 | 10:37 PM
Speedy650's Avatar
unbolt the fan and the clutch should come off with it. unbolt the clutch from the fan itself and bolt the new one on and put it all back on. shouldn't take much more than 30 minutes.
Old Mar 25, 2010 | 1:49 PM
TexanKing's Avatar
alright thanks guys, i wont be able to get another one till wednesday, since my truck isn't over heating would it be ok to still drive around until then?
Old Mar 25, 2010 | 3:18 PM
cam3439's Avatar
Yeah, but just keep an eye on the temp to make sure you don't overheat. Just make sure you get it done soon.
McPatty
Dec 2, 2014 10:38 PM
Grizbert
Dec 24, 2010 3:29 PM
marti25
Jul 20, 2010 9:57 PM
dozer157
Jul 1, 2009 6:03 PM
davtak
Jun 27, 2009 5:28 PM
