Faulty flasher?
Old Nov 5, 2010 | 11:43 AM
kickstartjoe's Avatar
Default Faulty flasher?
The flasher unit on my 1999 Silverado 2500 clicks irregularly when the turn signals are not on. Or, something else is clicking.
All the bulbs seem to be ok, including turn signals, parking lights, tailights and headlights.
Should I replace the flasher unit?
Joe
Old Nov 7, 2010 | 1:35 AM
lucian*91's Avatar
when it starts to make irregular clicking, turn on your flashers fast and see if it changes to regular or if blinkers change to irregular.. if you can hear that click and still one is irregular i wouldnt worry about it because its controlling something else
Old Nov 13, 2010 | 11:13 PM
suspect327's Avatar
i'm not sure if this is the same noise you're hearing, but every once in a while i would hear this weird sound. can't say it was a clicking, but an odd noise. the only time it would turn off is when i would dim all the dash lights with the switch, so i knew it had to do something with the lights. it turns out there is a little bulb next to the fuse panel and another under the glove box. i changed these bulbs and noise gone. hope this helps
sportlight82
Jul 25, 2009 3:24 AM
dozer
Mar 12, 2008 9:51 PM
yzman720
Apr 15, 2007 3:13 PM
kimmmba
Jan 10, 2007 8:31 PM
kimmmba
Jan 10, 2007 8:20 PM
