S-10 & Blazer 1982-2005
Flasher Problem w/1999 S-10 Blazer
Old Oct 17, 2006 | 3:55 PM
sportlight82's Avatar
Default Flasher Problem w/1999 S-10 Blazer
The turn signal flasher will start clicking on it's own for no reason. It may click a couple times or go on for a few minutes. Absolutely no pattern as to when it will start, stop or start clicking the next time. Turn signals and hazzard lights work just fine and I've replaced the OE flasher unit which did not help.
Any ideas?
Thanks Much,
Sportlight82
Old Oct 17, 2006 | 8:20 PM
golfer's Avatar
Default RE: Flasher Problem w/1999 S-10 Blazer
Had this same problem with 99 malibu , it was the multifunction switch. This is the left lever you use to engage the turn signals.
Old Oct 18, 2006 | 12:07 PM
Nomad76lj's Avatar
same for my 99 trailblazer cheap fix turn up the radio the switch is around anywhere from 200$ to 500$ canadian so mine still clicks whenever it wants to for now. hope this helps.
Old Jul 25, 2009 | 3:24 AM
Kenworth's Avatar
I have the same problem and yes from what I"m told from a friend of mine who is a GM dealer mech. it is the switch in your steering colum. I put a short bungy cord on it and hooked it under the dash. I found that with a little forward pressure it stops "ticking". cheap fix to an otherwise pain in the butt problem. and yes, the radio trick works too.
wadeh
Sep 25, 2011 8:16 PM
dozer
Mar 12, 2008 9:51 PM
yzman720
Apr 15, 2007 3:13 PM
kimmmba
Jan 10, 2007 8:31 PM
kimmmba
Jan 10, 2007 8:20 PM
