Flasher Problem w/1999 S-10 Blazer
The turn signal flasher will start clicking on it's own for no reason. It may click a couple times or go on for a few minutes. Absolutely no pattern as to when it will start, stop or start clicking the next time. Turn signals and hazzard lights work just fine and I've replaced the OE flasher unit which did not help.
Any ideas?
Thanks Much,
Sportlight82
Any ideas?
Thanks Much,
Sportlight82
same for my 99 trailblazer cheap fix turn up the radio the switch is around anywhere from 200$ to 500$ canadian so mine still clicks whenever it wants to for now. hope this helps.
I have the same problem and yes from what I"m told from a friend of mine who is a GM dealer mech. it is the switch in your steering colum. I put a short bungy cord on it and hooked it under the dash. I found that with a little forward pressure it stops "ticking". cheap fix to an otherwise pain in the butt problem. and yes, the radio trick works too.
yzman720
Apr 15, 2007 3:13 PM
