A few 2003 1500 HD questions..
Old Oct 7, 2008 | 2:26 PM
TXPalerider's Avatar
Default A few 2003 1500 HD questions..
I am new to the forum, but have lurked some in the past. I appreciate the wealth of knowledge that is available.
I've got a few issues with my truck and also need some basic advice and info.
First the truck is a 2003 Silverado 1500 HD 4X4 with approx. 91,000 miles. As the mileage is now getting up there, I figured it was about time to change the plugs and wires. My basic problem is, I'm not quite sure how to get the boots off of the plugs. I've twisted them side to side and pulled fairly hard, but, I'm afraid to pull too hard for fear I will cause damage. Is there a method to this? Or do I just need to pull harder? Frankly, I'm not sure I can get a hold on the well enough to pull them off. Also, does the metal shroud around come off with the boot or is it fixed in place?
Second, my truck has recently started idling rough at low RPMs, in fact it died last night for the first time. I know changing plugs and wires may help, but, what else should I be looking at?
And lastly, I have a terrible rattle when idling that appears to be coming from a loose exhaust joint. However, there is a metal "spacer" that seems like it would keep me from tighting the clamp any tighter around that joint. Any ideas on how to approach/fix this?
Thanks in advance. I would really appreciate any/all input.
Old Oct 8, 2008 | 1:23 PM
Default RE: A few 2003 1500 HD questions..
Anybody???
Old Oct 8, 2008 | 5:49 PM
x1cn18's Avatar
just pull harder they may break but if your changing them it dosnt matter the metal shields i think come out with the plugs as far as the rough idle possible fuel filter pressure regulator or even pump exhaust rattle not too sure i gutted all mine
Old Oct 8, 2008 | 10:41 PM
shawnvw's Avatar
Banned
Also make sure you clean out the throttle body for the low idle
Old Oct 9, 2008 | 7:55 AM
ORIGINAL: shawnvw
What is the best way to do that?
Old Oct 9, 2008 | 2:33 PM
jackyshaikh's Avatar
Clean it with AC DELCO carburetor spray,and wipe it with tissue paper.
Old Oct 9, 2008 | 2:40 PM
ORIGINAL: jackyshaikh
Should it be completely removed before doing that?
Old Oct 9, 2008 | 3:25 PM
Its up to you,but don't forget to remove battery wire before doing that.Better to clean it on vehicle.
Old Dec 16, 2009 | 8:41 AM
Cleaned the throttle body with carb cleaner and replaced the spark plugs and it ran like a champ.
The rattle was a loose exhaust clamp.
Cheesehead
Sep 5, 2014 9:22 PM
drifterdude
Sep 3, 2008 9:40 PM
clayton2127
Aug 14, 2007 9:17 PM
86_S10
Aug 2, 2007 7:36 PM
83 Chevy
Jul 19, 2007 6:42 PM
