Old Aug 10, 2015, 1:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
Fog Lights
Old Apr 6, 2013 | 5:34 PM
Firedawg8812's Avatar
Default Fog Lights
I am in the process of installing aftermarket fog lights and want to intergret it into the the factory fog light button, but i need help with the intergretion.
Old Apr 6, 2013 | 7:51 PM
mulmur1's Avatar
Welcome to the forum.
The way that the factory fog lamps are setup is through voltage always being applied to the fog lamp relay. When the fog light switch is turned on, a ground is applied to the body control module through the fog light switch circuit. The BCM then applies the ground to fog light circuit, allowing the fog light relay to power the fog light fuse.
You didn't state the year of truck you are adding the fog light to. It appears, based upon your picture that it is between 2003 and 2006. One option is the OEM fog lamp kit. It will provide you with all of the wiring, lamps, relay etc.
If the truck did not ship from the factory with the fog lamp option, you will require the wiring harness. Also, you will need to have the BCM program for the fog lamps, if you decide to use the OEM kit.
Good luck with your install.
Old Apr 7, 2013 | 2:53 PM
I have the factory relay it was preinstalled. I just need to know which wire i need to connect to so that both sets come on when i press the button
dcoperator
Mar 24, 2007 12:36 AM
07LS
Dec 21, 2006 12:38 AM
havic
Nov 13, 2006 7:56 PM
samsonitus
Sep 15, 2006 6:37 PM
mexican34
Apr 20, 2006 2:26 AM
