FRT Bearing Drivers side
The drivers side frt bearing is noisey AGAIN. New one installed at GM dealer at 111267km. Now truck has 224860km not impressed at GM right now. Truck is a 2004 Silverado ext. cab Z71 K1500 5.3L it will cost $409.14 MERRY FLIPPING CHRISTMAS
![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
Front hub bearings have regular service intervals. If the proper service intervals have been done at the proscribed mileage then you have another service issue that is causing the bearing to fail. If the services were not done then no foul on the truck.
My 96 has 260k and still has the original front bearings due to a regular preventive maintainance schedule,,,just some thoughts.
Charlie
Charlie
Charlie
Charlie
Like Tech2 said you deffinately want OEM bearings and any front end component really or youll just keep replacing them... The bearing is VERY easy to change though takes about 20 minutes. Just pop off the wheel and brakes, take off the axle nut, and its held in by 3 bolts on the back. You can also find dealer OEM parts about half price on Ebay...
I just replaced frt hubs on 02 silverado, used timken hubs, abs sensor was bad in one, had to use the sensor from the old hub, local guy wanted 270 for the timken hub and 130 to install, i got it on amazon for 115.,but was on my own when the abs started activating on dry roads.
anthony303
December 31st, 2014 7:57 PM
GM Fixer
September 7th, 2012 10:38 AM
Ron37388
December 14th, 2011 9:48 AM
